Ir para o conteúdo principal
The K-Gro PowerPro is a ridable lawnmower built for K-Mart by MTD and Murray. Released in 1997. Model numbers: 13AL452F120 (38", 12 HP) & 13AQ695H120 (46", 18 HP).
What size belts does it use
I need a deck belt what size is it
Esta é uma boa pergunta?
Pontuação 0
1 comentário
what is your model number?
por
Adicionar um comentário
1 resposta
Solução escolhida
Hey Britt.
You can find the right replacement parts for your mower (including belts) by using the mower’s model number to conduct an online search. You can usually find the model number on a sticker under or around the seat area. Also, on lots of models there may be another sticker (under the engine cover?) that shows the part number for the most common replacement parts, like belts and blades, etc.
Hope this helps.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
britt king será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Ao todo: 199
