Ir para o conteúdo principal
Monitor Black screen with faint light
Hello, my monitor suddenly went black and i can still see faint light that shows better in a dark room, everything is black inculding on screen controls and logo so problem not from pc or cable
Any ideas?
Imagem
The monitor is asus pg27uq
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi @netron
How long did you purchase it ?
had you tried with another input on the monitor ? e.g. hdmi or displayport?
normally when you disconnect the cables, there should be no signal found …
does it display normally?
normally monitors it should have 3 years warranty
https://www.asus.com/me-en/Monitors/ROG-...
I would suggest you to send in for service if you still have warranty.
Esta resposta foi útil?
Pontuação 1
3 comentários:
Thank you for your answer but unfortunately i bought it refurbished with 3 months warranty
And there is no input with any cable, the startup logo or the on screen menu doesn't even show, there is a slight light as shown in the pic
por
i have a feeling the backlight might be faulty.
take a torchlight and shine on the screen to inspect the display is in order....
some idea....
sometimes one faulty LED can cause this issues.
https://www.youtube.com/watch?v=iq7g2IT_...
por
The monitor got a little bump and working fine now, thank you
por
Adicionar a sua resposta
Ziad Althawad será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 29
Ao todo: 1,963
