Ir para o conteúdo principal
Um mouse gamer ergonômico na cor preta, lançado pela Razer em setembro de 2014. É o modelo mais popular da série DeathAdder. O número do modelo é RZ01-0121.
How can I replace button switches?
My switch on the right click button got broken. I can’t find a replacement on any site. How can I buy one?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Pergunta mais útil
Omron - D2F-01F (Japan), D2FC-F-K(50M)-RZ, D2FC-F-7M (20M), D2FC-F-K (50M)
I just replaced my switches with Omron - D2F-01F (Japan).
Those switch models are global numbers and easily searchable.
Kailh GM Red
Huano Micro Switches
TTC Gold.
Each of these manufactures also makes switches that work as substitutes but have a different tactile feel and actuation pressures.
Esta resposta foi útil?
Pontuação 2
4 comentários:
Any ideas what model is the middle switch?
por Compartilhar
Yeah any idea what the middle mouse switch is? it seems to be 1 mm shorter than the stock standard middle mouse switch.
por Compartilhar
I know this thread is old but I have a Deathadder Chroma and I successfully replaced the middle mouse switch with E-Switch part number TL1150AF070Q. I'm sure any switch of similar dimensions would get the job done, just make sure the actuation force is practical for your fingers. https://www.mouser.com/ProductDetail/E-S...
por Compartilhar
About D2F-01F - it is ok, but not for too long. I replace mine with this maybe 1,5 a year ago and now it makes double clicks again, maybe 2 times for 50 clicks, but still annoying at work. Glad I bough some DeathAdder just in case and another switch, so I will use DeathAdder in the meantime when I find some time to solder the new switch :)
por Compartilhar
You can use an old mouse switch it’s the same.
Pontuação 0
Adicionar a sua resposta
Emirhan Ulken será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 14
Últimos 30 dias: 45
Ao todo: 4,552
