Ir para o conteúdo principal
Informações de reparo para o teclado solar sem fio Logitech K750. Disponível pela primeira vez na Amazon em 2011. Números de modelo: 920-002912 (Windows), 920-003472 (Mac).
some keys changed their function
I dropped my keyboard face down and now the Y key is on the Z and some other keys type Greek characters. How can I get the total keyboard back to standard?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
Have you tried removing the batteries for a few minutes and then reinserting them? Also maybe check the voltage to see if they are getting low while you have them out.
Also read this thread…
To replace battery on keyboard
Esta resposta foi útil?
Pontuação 1
Z and Y switched is a sign that you are on the German keyboard layout (not Greek), so the problem is most likely your computer settings, not your keyboard.
Try WIN+ Space - that is the shortcut to change languages, sometimes hit accidentally.
If that doesn't work, go to the language menu and check things there.
Pontuação 0
Adicionar a sua resposta
Dan Woodward será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 15
Ao todo: 1,635
