Ir para o conteúdo principal
SodaStream Source is a new way to create soda in the comfort of your own home that allows you to personalize your beverage and make only the drinks you want, avoiding all the extra bottles.
Where to buy rubber seal for soda stream?
where i can buy rubber seal for my soda stream? I em in sous australia
Esta é uma boa pergunta?
Pontuação 6
Adicionar um comentário
1 resposta
I don’t own the unit so I can’t be sure of what you need. Here is a page for SodaStream replacement parts: Replacement Sealing Ring Gasket for Sodastream Nozzle Repair Accessories.
If you are hearing a hissing noise coming from your SodaStream Source, the carbonation tube is leaking gas, or the carbonation bottle is leaking, use the SodaStream Source is Leaking Gas problem page to fix the leak.
Esta resposta foi útil?
Pontuação -1
Adicionar a sua resposta
Anna Janicek será eternamente grato(a).
Visualizações:
Últimas 24 horas: 9
Últimos 7 dias: 38
Últimos 30 dias: 162
Ao todo: 12,613
