Ir para o conteúdo principal
Apple's third-generation smartwatch, with optional cellular connectivity, released September 22, 2017.
197 Perguntas Visualizar todos
Apple Watch 3 GPS 38mm screen/glass replacement
Hi guys,
So I was working the other day and accidentally smacked my wrist on something that caused my AW3’s screen to crack =(
Initially it was a small crack on the edge which I didn’t mind too much because touch was still working however I guess the crack got larger and now only my number 2 button for the pin code works. The rest of the touch is dead.
My question is:
1) Is it possible to change ONLY the top layer of the glass? If so, is there a repair guide on how to do this?
2) Can I buy ANY 38mm GPS Apple Watch on Ebay that is locked and just use the screen from that used watch? People are selling the NEW generic replacement screens for $150~ so I figured if I could get a used icloud/password locked 3 series watch I can just remove the screen from it and transfer it to my watch? Is there anything I would have to be worried about if I went this route?
Please help! Im hoping to get this fixed ASAP.
Thanks,
Tony
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
It is possible to replace glass only,but very hard. It is glued with the lcd and digitizer. To separate them you’d need a special heat pad,and specific tools to get in between the special glue and separate them then re adhere them without cracking the fragile lcd.
Or,you could buy the series 3 watch on eBay and use the whole lcd assembly screen from that and put it on your watch. This would definitely be the best choice…
The screen isn’t tied to the watch. So you can use it from another watch that’s locked.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
anthony será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 392
