Ir para o conteúdo principal
Released on October 23, 2012. Core i5 or Core i7 Processor. Apple Fusion Drive.
208 Perguntas Visualizar todos
Mac Mini stuck in reboot loop after PRAM reset
I’ve faced this a couple of times, and this is what happens -
I face issues with peripherals - HDDs, keyboards, mice, sound cards, what have you. I reset the SMC and sometimes they work fine. I try to do a PRAM reset and the Mac mini goes into an endless reboot loop. If i forcefully turn it off by holding the power button and then boot while holding the alt/option key, I get a choice of hard disks to boot from, and then I boot into normalcy (so to speak). But I have a nagging problem with a bluetooth keyboard (another post of mine) that I think the PRAM might solve, but I’m now stuck between the faulty keyboard and being able to get work done. HELP!
Esta é uma boa pergunta?
Pontuação 0
2 comentários
Are you using a wired USB keyboard or Bluetooth?
por
@danj I'm using a bluetooth keyboard and mouse
por
Adicionar um comentário
2 respostas
Pergunta mais útil
Why PRAM reset? Why not SMC? I mean SMC is more related to this than the PRAM.
Esta resposta foi útil?
Pontuação 2
1 comentário:
@fabledkebab - Correct!
In some models the Bluetooth keyboard won't be recognized early enough in the boot up process for the special startup keys which is why you often need to use a wired USB keyboard.
por
You need to use a wired keyboard and you really need to do a SMC reset How to reset the System Management Controller (SMC) on your Mac
Pontuação 1
Adicionar a sua resposta
aryansharma.info será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 7
Duração total: 491
