Ir para o conteúdo principal
Device name is Jensen 3 speed stereo turntable. Model is JTA-230.
9 Perguntas Visualizar todos
Why won’t regular headphones and earbuds fit in the headphone jack
We recently purchased this model turntable specifically because it has the built-in headphone jack. However, regular headphones/earbuds won’t fit the jack. Do I need to buy an adapter or return it?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
@sharpmom teh Jensen JTA-230 uses a 3.5mm headphone jack which is pretty much standard for headphones. The question now is what size is the connector on your headphones/earbuds. Measure the diameter of your connector and let us know what it is. Or post some images with a measuring tape next to it so we can see what you are dealing with. It is not the JTA that is unusual. If nothing else maybe you have a make and model for your headphones/earbuds Adicionar imagens a uma pergunta já existente
Esta resposta foi útil?
Pontuação 1
Buy an adapter. That is the first thing I would try.
Pontuação 0
Adicionar a sua resposta
Christine Sharp será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 64
