Ir para o conteúdo principal
A segunda geração foi apresentada como um modelo 2003 no Salão do Automóvel de Chicago de 2002, baseada na nova plataforma do Impreza, apresentando várias melhorias de ajuste em relação ao modelo anterior.
Why is the engine knocking after overheating
I ran the car out of oil almost completely and it overheated it's never overheated before it's been over a hundred thousand miles on it and now the engine knocks when we turn it on and I just put new oil in it. What do you think the NACA Muse
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Matthew Hyatt  This “I ran the car out of oil almost completely and it overheated” could be indicative of some major engine damage. From main bearings, to piston/rod damage and camshaft/ lifter/valve damage. I suggest that you have a mechanic at least do an inspection since it is a bit too much to go over. There are just to many variables with this.
Esta resposta foi útil?
Pontuação 3
1 comentário:
Thank you. For the record it was actually my girlfriend after I told her to put oil in it and ran it out of oil and overheated when I showed up it was knocking and had her to shut it off this is exactly what I told her that your answer confirmed it thank you very much
por
Adicionar a sua resposta
Matthew Hyatt será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 30
Ao todo: 1,672
