LCD leak bezel or lcd itself?
My Powerbook's screen is leaking pretty badly at the bottom to the point it's distracting. Is the problem with the bezel or the lcd itself? Which do I need to replace?
Esta é uma boa pergunta?
There's nothing in the bezel to leak. This sounds like you've cracked your screen. Here's how to replace it: PowerBook G4 Aluminum 12" 1-1.5 GHz LCD Replacement
Here's the part that iFixit has. I would look at the back of your screen and contact them to make sure the replacement will work.
[produto vinculado ausente ou desativado: IF153-082]
Esta resposta foi útil?
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 5
Duração total: 582
1 comentário
Thanks, I meant light leak on the surface of the lcd itself. I assume the fix is the same -- a new panel. Thanks.
por les
