Ir para o conteúdo principal
Informações de reparo e resolução de problemas para o Dell Alienware 13 R3, um notebook gamer produzido pela Dell.
Red light flashes but does boot.
This a work computer that was gutted and by an ex-employee. I am trying to put it back together however it won’t boot. If I hold the power button down for a few seconds red light pulsate but not thing happens. No fans ramping up or nothing. Please help.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Are you using the original charger that comes with the laptop? Sometimes if the charger is not powerful enough / original it may refuse to charge the battery or power the laptop without battery.
Try these if you haven't already:
  • Powering it on without battery but charger plugged in.
  • Unplug any non major components for turning the laptop on such as USB daughter boards, optical drive, speaker cable.
  • If there is a coin battery present in the board try removing that for 5 minutes then put back in and try turning the laptop on. That resets the settings on the board's bios.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Arnavick Tendilla será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 22
Ao todo: 4,965
