My laptop does not start up.
My Macbook Pro does not start up. It is completely dead. The charging light is on, when plugged in. When I press the power button (plugged in) the fan comes on after some time and stays on. The charging light goes from yellow to green (looks normal). I tried SMC reset on the dead machine, no change.
Esta é uma boa pergunta?
4 comentários
There are two versions of this series one with a dedicated GPU and the other without. Do you remember which you got or plug in the systems S/N here EveryMac - Lookup The S/N is on the bottom cover if you can't read it see if you can plug in the model ID often times I can read them a bit easier. Let us know which you have (IG or DG)
por Dan
Hi Dan
Thanks for the quick response. I looked up this one, it is a DG.
por Ashok Hanumanth
OK, lets try this quick test. Restart your system and press and hold the 'T Key which you would use to enter the system into Target Disk Mode. Are you seeing the Thunderbolt icon on the display?
por Dan
The system does not start at all. Tried pressing T + Power button no response.
por Ashok Hanumanth
