Ir para o conteúdo principal
2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
561 Perguntas Visualizar todos
I replaced both the I/O cable and card and no change
Hello.
I have an issue with my Right USB port.
After replacing the battery on my 15” retina from mid 2012. I replaced both the I/O cable and board and no change. Flash card and HDMI ports work fine.
USB works with some devices but not others. It does provide power to the devices, just doesn't see them.
Esta é uma boa pergunta?
Pontuação 0
6 comentários:
Did you damage the new I/O cable and/or damage the I/O cable connection point on the logic board?
Post some pictures of the cable connectors on the cable itself, the connection point on the logic board, and the connection point on the I/O board itself.
por
@mike_lemke - Now you got it!
Here's a guide on how to post a picture or a file as it can be a bit confusing Adicionar imagens a uma pergunta já existente
Note: I posted the URL within the square brackets [ & ] in the case of iFixit guides it will auto fill in the title. If this was someone else's URL you would use a bar ( | ) within the bracket space to post the title you want as an example [ URL | Name]
por
@danj Thank you, and noted!
por
What operating system are you running? Did this happen after a system upgrade?
por
This happened after I replaced the glued-in battery. The battery replacement went well and I didn't damage anything. But now the right side usb port has this issue. I tried a new I/O board and flat cable but didn't change anything. I'm thinking it a fuse link that went bad somewhere on the logic board, downstream from where the I/O board connects to the logic board?
por
Exibir mais 1 comentário
Adicionar um comentário
1 resposta
Let's get a picture of the ribbon connectors on the logic boards (both) I'm thinking one is damaged. Nice tight crisp shots. Adicionar imagens a uma pergunta já existente
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Noah Landis será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 40
