Ir para o conteúdo principal
Lançado em 26 de outubro de 2018. Modelos A1984, A2105, A2106, A2108. Disponível como GSM ou CDMA / eSIM, nano-SIM ou SIM dual / 64, 128 ou 256 GB / Preto, Branco, Azul, Amarelo, Coral ou Vermelho. (Pronuncia-se "iPhone 10 R.")
How to replace : iPhone XR Rear Camera Lens Cover
Will heat release the glue of the. Lenses COVER.? I bought the lense cover but I can not find anything as to how to remove just cover by itself!?, anyone have a step by step guide or a video that you have discovered?
Thank you,
papa
Esta é uma boa pergunta?
Pontuação 4
1 comentário
I used a paper plate cut a hole out the size of the rear lense and used the tip of a regular iron and kept the body of the iron away from the phone! Once it was on for about 5 seconds I used a single edge razor blade to remove small bits of glass from the ring. I immediately vacuumed any debris from the phone or the paper plate i had below the phone!
2 paper plates, iron ( no steam ) alcohol to clean camera, vacuum cleaner, jewelers glasses, white light!
por
Adicionar um comentário
4 respostas
Pergunta mais útil
The glass is stuck on there really good and just heat will not help much. The glass will just keep breaking while you remove it and some will get inside. The best way to do this is by taking apart the phone and removing the camera to be able to prevent it from getting damage. You can also try using a small tip vacuum cleaner right at the camera while prying out the glass bit by bit while keeping it warm so it doesn’t end up falling in the camera.
Esta resposta foi útil?
Pontuação 1
Did anyone ever answer this? I also got a lens with cover when ordering the part.
can I remove the lens housing from the Backglass without cracking the back?
Pontuação 0
I bought a Replacement lense with the iron ring around it.. how can i replace that?
Pontuação 0
1 comentário:
The problem is i bought the full lens with metall ring…
por
I replaced the lens without taking the phone apart.
Somewhere someone recommended using a utility knife and carefully breaking the lens out piece by piece.
I did that with a utility knife and finished up with an X-acto knife. It worked fine for me.
Pontuação 0
Adicionar a sua resposta
Get Up & Go Now será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 19
Ao todo: 15,096
