Ir para o conteúdo principal
Impressora jato de tinta de escritório lançada em janeiro de 2009. Número do modelo G510n.
printer will not scan to file
My printer will not scan to file. It also is missing black and white
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
For not scanning to file, you are talking about the option to save file to a network location? If so check these few things:
  1. Check if you configured your location properly. It should be something like \\computername\sharename
  2. Make sure your computer/laptop and printer have same workgroup name.
  3. If there is username/password to your profile, add them as well to printer (in network settings) so it can write file to given location.
As for “missing black and white” I am not sure what you are referring to? If you are reffering to printer options, I think its “Grayscale” that needs to be selected “on” or checked.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Marlene Nummer será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 15
Ao todo: 457
