Ir para o conteúdo principal
Repair and disassembly guides for Garmin GPS devices.
Replacing the digitizer glass
I just purchased a replacement glass for my Garmin Edge 800, but it is just the glass and not the glass in the frame. How do I remove the cracked glass from the frame and install the new one? The original appears to be glued to the frame
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
@dwiener
use a good hair dryer or a heat gun on its lowest settings. Move the hot air along the sides of the digitizer to soften the glue. Once soft, use a thin tool to replace the digitizer.
Esta resposta foi útil?
Pontuação 0
2 comentários:
I’m trying a hair dryer. The case is getting hot, but the glue doesn’t appear to be softening. About how long should it take?
por
@dwiener big depends on the glue they are using. It is most likely a adhesive strip. Try a guitar pick and loosen it when the heat is relatively high without melting the case.
por
Adicionar a sua resposta
Dennis Wiener será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 14
Ao todo: 481
