Ir para o conteúdo principal
Mr. Potato Head is an American toy consisting of a plastic model of a potato which can be decorated with a variety of plastic parts that can attach to the main body.
3 Perguntas Visualizar todos
How do you fix a loose arm on this toy
Hi my mr. potato head arm is loose how do I fix this
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Solução escolhida
Munch Fazbear  either the end of the arm is worn down (to small) or the hole inside the head is worn out (to big). If it is just one arm that is loose measure the ends and compare the results. If it is the arm you can get replacements. If the arms are pretty identical then measure the “hole in the head" (do both arms feel loose in the same hole and fit properly in the other). You can get replacements for that as well. Of course if you have 3D printing capabilities you could always make some replacements.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Munch Fazbear será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 20
Duração total: 819
