Ir para o conteúdo principal
2.2 GHz (Turbo Boost up to 3.4 GHz) or 2.5 GHz (Turbo Boost up to 3.7 GHz) quad-core Intel Core i7 processor with 6MB shared L3 cache.
467 Perguntas Visualizar todos
Apple MacBook Pro - laptop screen cracked
The lower left screen got a hole/cracked - only 15 % of the screen area is effected with left 20% of screen area with lines . Does it need a complete screen replacement or the crack can be fixed . Also, let me know total cost of repair
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
What model specifically? I think there are 21 MacBook Pro models that match the A1398 model number, you may wish to lookup yours by EMC NumberModel ID, or Serial Number for greater precision.
Esta resposta foi útil?
Pontuação 1
1 comentário:
As the OP did post the exact model I don't think we need to assume its a different system than what he stated: Mid 2014 15" MacBook Pro
por
You’ll need a new display assembly, there is no means to patch the glass.
Here’s the needed part MacBook Pro 15" Retina (Late 2013-Mid 2014) Display Assembly and here’s the guide you’ll need to follow MacBook Pro 15" Retina Display Mid 2014 Display Assembly Replacement
Imagem de MacBook Pro 15" Retina (Late 2013-Mid 2014) Display Assembly
Produto
$319.99
Pontuação 0
Adicionar a sua resposta
Shawn Noor será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 465
