Ir para o conteúdo principal
Flagship phone from Huawei presented in October 2018 in London. Models LYA-L29 and LYA-L09 available with 6/8 GB RAM and 128/256 GB storage. Triple camera setup, 4200mAh battery and in-display fingerprint sensor.
17 Perguntas Visualizar todos
Huawei mate 20 pro went charge
I have the Huawei mate 20 pro and I'm having issues with charging device. Even if I use the original cable and plug, phone doesn't charge and also does acknowledge headphones when plugged in
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
rachid qui  that is still a pretty new phone. Check first to find out if this will be covered under warranty. Normally I would say it is the battery but this phone is still to new to have battery issues.
Esta resposta foi útil?
Pontuação 0
2 comentários:
I think it might have something to do with the charging / headphone port because it doesn't recognise either
por
Sounds like some board issues. I'd definitely check the warranty first. I do hope you get it fixed.
por
Adicionar a sua resposta
rachid qui será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 10
Duração total: 1,310
