Ir para o conteúdo principal
The iMac G3 came in tangerine, blueberry, lime, grape, and strawberry colors.
18 Perguntas Visualizar todos
iMac g3 boot from dvd
I have an imac g3 from 1998 I am trying to wipe the hard drive as I got the computer from a recycling place and am trying to reinstall mac os 9.2.2 on it. I cannot boot from the dvd. I only have a Microsoft keyboard and mouse. I have tried the “alt” key and on a forum someone said to use the “ alt” and “r” key. Nothing has worked so far. When I try those keys it boots up from the hard drive. Instead of going to boot menu.
Esta é uma boa pergunta?
Pontuação 0
2 comentários
Tell us about the installation disk you are trying to use. What color is it? If it is gray is there a part number on it in the lower left hand area?
por
The disc is gray. It says imac mac os 9 install. The part number I believe is 691-3783-A.
por
Adicionar um comentário
2 respostas
Solução escolhida
As soon as you turn the computer on, hold down C on your keyboard and it should boot from the CD. If that doesn't work, you can hold down option until the boot menu comes up and choose the CD from the list.
Esta resposta foi útil?
Pontuação 0
Yes, normally ALT is a good suggestion without a Mac keyboard, as Windows keyboard ALT works the same as a Mac keyboard's Option key for me if I am using my Windows keyboard plugged into my G4 Mac but I think G3 computers don't support Option at power-on time. Even with Apple keyboards (I tried USB and ADB keyboards from Apple) I cannot get Option to work on my G3.
Pontuação 0
Adicionar a sua resposta
Kevin Greaves será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 15
Últimos 30 dias: 83
Duração total: 3,567
