Ir para o conteúdo principal
Repair guides and support for the Huawei P9 Lite, released in April 2016.
74 Perguntas Visualizar todos
Bootloop because of fingerprint scanner?
So, they gave me a p9 lite to check as it was getting pretty hot and it's fingerprint scanner wasn't working. Opening it revealed a disconnected scanner and no thermal pad. I plugged it in and it started bootlooping. Cache clear, factory reset and flashing the proper rom from a sd card didn't solve the issue, what can i do besides getting a new motherboard?
Esta é uma boa pergunta?
Pontuação 1
1 comentário
The thing is, it was working fine before, could this be caused by ESD?
por
Adicionar um comentário
2 respostas
Solução escolhida
So, i fixed it. What i did, was buy another cheapo broken p9 lite for parts. When I swapped the motherboards, both phones were working for some reason, but when i put mine back in it didnt, until i swapped the fingerprint scanners aswell. I have no idea why or how this works, but it fixed it for me.
Esta resposta foi útil?
Pontuação 1
Pergunta mais útil
Absolutely nothing. You can’t even put custom roms. They LOCKED the bootloader unlocker
Update (06/08/2019)
https://forum.xda-developers.com/p9/help...
Pontuação 2
Adicionar a sua resposta
ognyan796011 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 7
Duração total: 308
