Ir para o conteúdo principal
Após anunciar a descontinuação do Durango após o ano modelo 2009, a Dodge lançou um site na Internet e fotos teaser da terceira geração do Dodge Durango em 16 de agosto de 2010.
Metallic connectors inside key fob not attached to silicone button pad
Imagem
Imagem
Imagem
My metallic connectors inside key fob not attached to silicone button pad & have become detached - so the whole fob is no longer working. What is the best adhesive to try and re-attach the metal connectors to inhibit them from wondering around causing a mess?
Esta é uma boa pergunta?
Pontuação 2
7 comentários
Can yo post some pics so we can see what you are facing here Adicionar imagens a uma pergunta já existente
por
You appear to be missing some of the pads! Correction: I count five here two is still in the key and three on the table. You need seven!
por
The key fob only shows 5 buttons on the front. There are 3 on the table and 2 of them still in the key fob. They look pretty dirty and need cleaned to make a good connection with the board.
por
All these comments are good, but I had the same problem with my key fob. When the discs become dislodged that particular button will not work. Mr personally,I used Super glue, just a touch...
por
I used contact cement
por
Exibir mais 2 comentários
Adicionar um comentário
10 respostas
Pergunta mais útil
as a locksmith, we see this problem often. we clean the board with alcohol pads after removing the battery. remove all discs from the back of the silicone pad. be sure to clean/scrape the contact cement off the back of the discs. once everything is clean, center each disc over the circuit it was intended to touch. get a 3” strip of clear commercial tape. have someone give the “non” sticky side a quick spray with anti static spray. the discs will move if not done. lay the tape over the top of the entire board and cut away any excess around the edges. reinstall your battery and you should be good to go afterwards. there’s no place for those discs to slide around after taping them in place. hope this helped!
Esta resposta foi útil?
Pontuação 4
3 comentários:
I actually had taken my fob completely apart before reading this. There were only 3 electrodes, but I removed them, then cleaned them and everything on the fob, inside and out. I taped the electrodes back in place per above, and the fob is working perfectly. - well, the lock/unlock and trunk buttons since I placed the 3 electrode pads over those buttons. I am now hoping that my windows stop going up and down, the lights stop turning on and off, and the trunk stops popping up! I'll report back in a week with an update.
por
Lol. That's hilarious
por
Thank you so much Steve, this has been a headache of mine for MONTHS. I hope this truly works for a long haul, because I do not have $180-$200 to have mine replaced. I'm already needing to get another made just to make sure I have two of them. (one as a back up, I only have one since that's what the dealership gave me, two keys, one fob (used truck)).
por
Take the fob apart. Careful not to lose the little steel discs.
Remove all the little switch discs and set them to soak in an alcohol bath to remove any contamination.
Use alcohol to clean the surface of the PC board. If needed, use a pencil eraser to remove any contamination or oxidation.
Wipe off and allow the discs and PC board to thoroughly dry.
Carefully place one little steel concave side down over each used switch target. Note: Many fobs do not have all the switches used.
Place a strip of Scotch Magic Tape to cover all the discs and press down to make sure it adheres to the PC board with all the discs in place.
Trim excess tape from around the PC board.
Assemble the fob. Check each switch to ensure it can be heard operating as you push it. Try the fob.
See: https://www.youtube.com/watch?v=dagH0ZN_...
Thank you. Rich Knowles
Pontuação 2
1 comentário:
"Careful not to lose the little steel discs."
Uhhhh, too late! Any idea where I can get replacement discs?
por
I suggest taking a look at the following YouTube video I produced in Oct 2016.
https://youtu.be/dagH0ZN_2A0.
Pontuação 1
Clean both the metal buttons and the gold circles with a little bit of rubbing alcohol. You want them to be shiny metal again because that’s how your fob works to close the circuit for each button. You can use a paper towel or a clean cloth. Dry them off and use some clear tape to hold them in place on the circuit board where they need to be for your buttons to work.
Pontuação 0
@normlscrindy
The bottom two buttons on FOB are not connected. 3 is the right number for a total of 5. Those “pads” are what closes the circuit when you push the button. Clean the contacts on the circuit board, as well as the pads, carefully with an eraser. Than place the buttons on the little nips on the FOB. You can just use a little bit of vaseline or other slightly sticky substance between the pads and the rubber for the FOB. With all 5 of the membrane pads back on the rubber, place the circuit board over it and assemble the FOB in such a way that the little contact pads are always on the bottom (let gravity help you). Once it is assembled the pads are being held in place simply by the board. They got nowhere to go.
Of course, if you are in doubt use a very small amount of super glue on the rim of the contact to glue it to the “silicone button pad  “
Pontuação 0
I also have this issue on a 2012 Ram key fobs. As a pair of them on ebay & else where are $13 & up, I plan on getting a new pair and swapping out the circuit board only from the old fobs to avoid having to reprogram them or at least till I find a way around the reprogram fee.
Pontuação 0
1 comentário:
Did this work? The reprogramming costs more than the fobs.
por
I recently had the same issue, I've used silicon adhesive. I figured that super glue would made the connection stiff and would not allow the button to work properly. It's working fine
Pontuação 0
My first suggestion is to buy a new button pad that has he connectors attached properly. You can buy them online, I suggest finding your vehicle year, make, and model on this website https://keylessentryremotefob.com
Another suggestion would be to place tin foil as a substitution for the connectors. That should get you by for awhile.
Pontuação 0
Where can I get the metal discs if the have been lost?
Pontuação 0
1 comentário:
Have you ever found the metal discs as i am needing them too exactly like the ones pictured above in the original post
por
You can buy the shell from Amazon: https://www.amazon.ca/s?k=dodge+caravan+...
It comes with the metal discs inside.
Pontuação 0
Adicionar a sua resposta
cindy h será eternamente grato(a).
Visualizações:
Últimas 24 horas: 7
Últimos 7 dias: 78
Últimos 30 dias: 391
Ao todo: 27,168
