engine knocking top of engine as it warms up its not so load
what can I do to fix it? is the oil pump going bad?
Esta é uma boa pergunta?
Gregory Carlson we would need to know the exact year, model and size of the engine. The knocking could be unrelated to your oil pressure. Of course, you do want to check it with a proper gauge. Also, make sure you changed the oil, filter etc and checked your oil level. After that do a compression test and a leakdown test. Let us know what you get on those.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 39
