Ir para o conteúdo principal
Repair guides and support for the 5th generation Honda Civic, first released in late 1991.
52 Perguntas Visualizar todos
Why don’t my gauges work?!
so I own a 1994 civic dx and my guages stoped working, One Day I was just driving, used my turn signal and my speedometer went up and down then it never turned on again. So now when when I’m driving and my speedometer is at zero, my temp goes to cold and my gas goes to empty, but some of the lights still work... switched it with a different cluster thinking that was it and same thing, light work signals and gauges don’t, if anyone knows what could be the problem please help!!
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Pergunta mais útil
@torres367 check for a bad ground or connection. Remove all connectors and check those. Try the cluster self diagnostic test.
Press and hold odometer button
Turn parking lights on.
Turn ignition to ON
Turn parking lights OFF, ON, OFF then press odometer button 3 times.
You can start the engine in the mode but the gauges will not work. To cancel this mode shut off ignition.
Of course you also want to check all of your fuses. I think (will verify later) that your backup light also fuses the gauges. Let us know what you find
Esta resposta foi útil?
Pontuação 1
2 comentários:
What is the purpose of this diagnostics? All it does is turn off the gauges, then what do you diagnose?
por
@Patrick Lamastus it only checks the cluster to see if that is where the error is. If it does what it is supposed to do, your cluster is okay. That way you don't get this "switched it with a different cluster thinking that was it and same thing" and spend your money on something you don't need.
por
if your gauges such as the fuel gauge and the heat gauge and the rpm meter gauge and the indicators dont work at all there is a blown fuse its 20amps fuse change that fuse and if these problem occurs again there might be a short somewhere in the wires.
Pontuação 0
Adicionar a sua resposta
Angel Torres será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 14
Últimos 30 dias: 55
Duração total: 1,207
