Ir para o conteúdo principal
O Samsung Galaxy J2 é um smartphone Android que foi lançado em novembro de 2016.
Why my recent apps button is worked automatically?
If I will use my mobile phone for more than 10 minutes it became very heat and the recent apps button pressed automatically. It irritates me.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
If your phone gets hot after only 10 minutes and seems to malfunction, then it may be infected with malware. Performing a full factory reset is a sure-fire way to remove malware from your phone. The reset can be done in your phone’s Settings.
Esta resposta foi útil?
Pontuação 0
3 comentários:
It doesn't work
por
“It doesn't work” is a bit vague, please be more descriptive because I can't see what you are seeing. You said that your phone starts to overheat and malfunction after 10 minutes. Are you unable to get into your phone's Settings before the 10 minutes are up?
Being able to reach the Settings app would really help fix the issue.
por
saya sudah melakukan di hp samsung j2 saya tapi masih seperti itu
por
Adicionar a sua resposta
Às Âsrår será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 14
Ao todo: 1,378
