Ir para o conteúdo principal
Model A1286. Released February 2011 / 2.0, 2.2, or 2.3 GHz Quad-core Intel Core i7 Processor
586 Perguntas Visualizar todos
Only starts if I first disconnect battery for a few seconds
I have a mid 2011 MacBook Pro which shows green light on mag, but will only boot if I disconnect the battery for a few seconds. I tried 2 different batteries, both show over 95% design capacity. The laptop boots with just mag power after a few seconds without battery. I have continuously unplug the battery to get it to start. However, restart seems to work OK. Baffling...yes it is the dreaded 820-2915 but this is not kernel panicking…yet. Actually was able to run “Heaven “on it, so GPU seems fine for now.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Ever spilled anything on the keyboard, sounds shorted out to me.
Let’s take a better look at it. Please run Coconut Battery and post your results.
https://www.coconut-flavour.com/coconutb...
Esta resposta foi útil?
Pontuação 4
1 comentário:
Hey Mayer, as usual, you rock. I did put the logic board into another A1286 case, therefore another keyboard, and the issue is resolved. Humble bow into your general direction,
por
Adicionar a sua resposta
Jurgen será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 61
