Ir para o conteúdo principal
Uma câmera digital SLR de 10,2 megapixels da Nikon.
Cannot transfer photos from camera to computer
I have photos in the camera - cannot transfer them to computer using view/delete because “this option is not available with current settings.” Immediately preceding this, I had no trouble transferring photos to the computer.
Esta é uma boa pergunta?
Pontuação 1
1 comentário
How to snap with any Nikkon or other and show on my computer without copying or transferring it for immediate work
por
Adicionar um comentário
1 resposta
Solução escolhida
If it takes a memory card try using a memory card reader their super cheap and easy to use and offer faster data transfers usually rather than going though the camera. Take the card out of the camera insert it into USB memory card reader (ur laptop/PC may even have a slot built in for sd cards) plug it in browse for dcim folder get what u need :)
Esta resposta foi útil?
Pontuação 0
3 comentários:
I try purchasing a memory card reader. Thx
por
Before u do if ur using a laptop a lot of them did or do come with a sd card slot somewhere on the side :) it was the big thing a while ago
por
A card reader is a better option than using the camera as a card reader as it is faster and you are not using camera battery which may need charging if you used it up while out taking photos. Card readers are fairly cheap currently
por
Adicionar a sua resposta
SLarsen será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 20
Ao todo: 1,095
