Ir para o conteúdo principal
Garbage screen after 5-10 minutes
I have 8 years old setup.
Intel E5700 3.0 GHz dual core
4 gb ram
Gigabyte g41 series motherboard
Integrated graphics
Windows 7 Ultimate
The setup was unused for last one year. when I started it again then cmos failed. So I replaced battery and cleared cmos. This turned it on.but now it has display problem. I have attached picture for reference(ignore the white circle, that’s my camera flash). It works fine for few minutes. The cooler the atmosphere, the longer it works.
I have checked PSU. It works fine. CPU runs at ~87 °C before automatic shut down. I don't know how to check video card as it is integrated. I took it to local service guy, he says it is bad RAM. I tried to run memory diagnostics but it doesn't give me enough time.
Please tell if there is something I can do. Thank you.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
@prashantpatel
could be bad RAM module as well as a bad GPU. You can either replace your memory module or install a new video card. There is no way to test it unless you have another machine to insert the parts to test by exclusion.
Esta resposta foi útil?
Pontuação 2
3 comentários:
Thanks for answer.
I bought new RAM but still same issue. And about GPU, it's onboard GPU of GigaByte motherboard. E5700 cpu with no graphics. Any chance of bad Motherboard?
por
@prashantpatel try an inexpensive video card instead of using the onboard video.
por
@oldturky03 I checked my RAM sticks with my uncles PC and I found out that It was because of BAD RAM slots. So, I replaced motherboard and now it works fine.
por
Loose RAM cards? If you remove RAM while the system is running, and plug it back in, then it'll display garbage like that. (Accidently pulled out a RAM stick on a laptop. Never made that mistake again).
Try reseating your RAM, and see if that fixes it. Or maybe get a different stick and see if boots fine.
Good luck!
Pontuação 1
1 comentário:
Thanks for Answer.
I bought new RAM but still same issue. And about GPU, it's onboard GPU of GigaByte motherboard. E5700 cpu with no graphics. any chance of bad motherboard?
por
Adicionar a sua resposta
Prashant Patel será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 11
Últimos 30 dias: 55
Duração total: 5,605
