Ir para o conteúdo principal
O Asus Zen AiO Pro Z240IC é um computador desktop tudo-em-um (all-in-one) conhecido pela sua tela 4K de ultra-alta definição e disco rígido de um terabyte.
Display not working after Motherboard Installation
I purchased a replacement motherboard (v 1.4) and have installed this according to the procedure shown in this guide. The motherboard powers on, the fan spins as it should but there is no display showing. I have tried reinstalling the RAM and re-booting but no luck . The display still does not show.
Does you have any suggestions? I am at a loss at the moment.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Solução escolhida
Its turned out to be a faulty motherboard. I bought a replacement from Alliexpress and it has worked perfectly. Got into the Bios 1st time round without an issue. We think that the graphics card on the old motherboard was the problem.
Thanks for all the help.
Esta resposta foi útil?
Pontuação 0
Pergunta mais útil
If you haven’t done so already, look through the ifixit guide again and recheck all your ribbon cable connections.
Does your model have the HDMI port? If so try connecting to another monitor or TV to see if you get anything.
Pontuação 1
2 comentários:
I have checked all the ribbon connection cables. I have even tried connecting to another monitor. It is probably something simple but at the moment I can’t work it out.
por
So you see nothing on the screen, not even able to get into BIOS?
por
Adicionar a sua resposta
Manjinder será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 17
Ao todo: 733
