Ir para o conteúdo principal
Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1158 Perguntas Visualizar todos
Cant get screws out with #00PH
Ok so Im trying to get to my on/off button and the 5 screws holding the logic board down wont come out I tried to apply pressure and nothing, screws wont turn or move im just making it even harder since the tread in the screw is wearing. how can I get the screws out?
Esta é uma boa pergunta?
Pontuação -1
1 comentário
Ok im thinking its the screwdriver set I just got. it was pretty cheap. whats the best brand to buy for the IPhones? need one with a strong magnet, noticed the last two I tried were way to weak for the case screws and even worse the 2.3mm size ones. Suggestions?
por
Adicionar um comentário
3 respostas
Solução escolhida
The screws are Philips #00. Take the iPhone to the Hardware store and demo a few screwdrivers right there. Actually I have had luck at the 99cent Store they sell the cheap kits with about 10 mini screwdrivers, often two of the Philips from the kit will work perfect with the iPhone, again demo on iPhone in the store first.
Regarding magnetic screwdriver, never buy one. Take any magnet, even a refrigerator magnet, and run it along the screwdriver pulling it straight off the tip. Do it a couple of times for greater strength (will last for months). To demagnetize run the magnet the other way.
Esta resposta foi útil?
Pontuação 2
1 comentário:
Thanks that worked! and I found a 46 piece precision tool kit for $6 steel.
por
If you're going to be doing any more electronics disassembly, we highly recommend our 26 Piece Bit Driver Set. It contains driver bits for all common screws for cell phone repair, as well as bits for most screws used laptops, video game consoles, and more. It has all of the common phillips sizes, torx sizes, and tons more. It even comes with a 6 month warranty if any of them break. We guarantee that it will work on your #00PH problem.
Hope this helps!
Pontuação 0
To get the screws out that are already messed up try this extractor set: Precision Screw Extractor Set
Imagem de Precision Screw Extractor Set
Produto
$24.99
Pontuação 0
Adicionar a sua resposta
Ryan será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 4,123
