Ir para o conteúdo principal
The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
1185 Perguntas Visualizar todos
Lines on the screen
Okay so last year my macbook fell from a table straight down to the floor. The tip of my macbook’s lcd is dent now due to that fall but there were no lines or whatsoever. a year later probably 3 weeks ago, I woke up as usual and when I open my macbook I saw this horizontal line stretching from the tip of the right side of my macbook screen (the dented one) all the way to the bottom left. So I tried to touching the line, I felt nothing, no physical damage. Usually when something cracks, you can feel the crack with your finger but when I tried to feel this “line”, I literally cant feel any signs of crack and its probably damage from the inside but I have no idea how. What should I do? Should I fix this one or are there any other solution?
(the last image shows what happen if I apply pressure to the horizontal line, but it usually goes away after a few minutes to hours.)
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Cracked. You can’t feel the cracks on laminated glasses easily.
Unless you can feed it nice food and let it heal by itself, your only option is to replace the display unit.
MacBook Pro 13" Retina Display Early 2015 Display Assembly Replacement
Esta resposta foi útil?
Pontuação 3
2 comentários:
Aight then thanks for the advice! I'll try feeding my macbook so that the lcd screen will heal overtime. thanks Tom!
por
Yeah probably will leave a scar anyway, maybe just replace it.
por
Adicionar a sua resposta
Jonathan Kim será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 1,227
