Ir para o conteúdo principal
The Canon Powershot A590 IS is an 8 megapixel digital point-and-shoot camera with a 4x optical zoom and a 2.5 inch LCD screen.
20 Perguntas Visualizar todos
How do you expose the lens/sensor to blow dust off?
I can open the case but how do you get the lens/sensor exposed to blow the dust off the lens and/or sensor?
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
2 respostas
Solução escolhida
You have to remove the lens assembly from the camera then open it to reach the sensor.
Esta resposta foi útil?
Pontuação 2
2 comentários:
Thanks for the reply, but how do you remove the lens assembly and open it? Is there a procedure/exploded view? from Canon?
por
Canon service manuals are pretty hard to find but maybe oldturkey03 could check if he can find it ?
The only tutorial I can find is how to replace a bad LCD panel on a A590:
http://www.youtube.com/watch?v=dfXG1OAgc...
por
Se if this will help to get the lens cover off Canon PowerShot A590 IS Flash Assembly Replacement
Pontuação 0
1 comentário:
Thanks, but this procedure does not continue to lens assembly removal/opening. Is there a continuing procedure available?
por
Adicionar a sua resposta
george será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 1,327
