Ir para o conteúdo principal
Volume very low from shuffle. Used to be fine...
Hello, refound my shuffle after about a year and charged it up, plugged in the headphone and now I can't increase volume, I can barely hear the music.
Never had a problem before so thought fault lay with the headphones, bought a new pair and issue still there.
Any ideas…..?
Esta é uma boa pergunta?
Pontuação 1
1 comentário:
Hi Adele, You can only raise the volume with the headsets right?
Which kind of headsets are you using ? The older ones or the newer ones? Perhaps there is a difference in them.
por
Adicionar um comentário
1 resposta
Trashed battery? Dirt in the contact pins?
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Adele será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 4
Ao todo: 406
