Does a LTE display work on a GPS only watch?
I there!
Will a Series 3 LTE display work on a GPS only watch? I’am asking because the price difference is 150 Yuan (the LTE variant is much cheaper…).
Esta é uma boa pergunta?
I there!
There are some discussions on this but as I recall you cannot use different screens or there will be degraded operation.
Esta resposta foi útil?
I just tried putting a display of an AW3 GPS onto an AW3 LTE.
I even tried moving the original NFC module of the LTE version onto the GPS’s display and ended up with pairing issues.
Was able to solve the pairing issues by using the display + NFC module from GPS version but had to sacrifice support for Apple Pay.
There is already a discussion about this topic here: Why won’t my watch pair after screen replacement?
Recently I had changed my screen on Apple Watch series 4
I don’t know which screen has fixed by technician but after change my watch very slow booting & I did erased my watch
Then while pairing to my iPhone it was unpairing automatically without any pop up
Is it caused with new screen or flex cable
Unfortunately I don’t have old screen
Please help to what is right solution
Putting a GPS only screen onto a GPS+LTE watch would obviously have problems, did you try the other way around? A GPS+LTE screen onto a GPS only watch? Thanks
I’ve put a gps lte screen on a gps only, it works and comes on but touch doesn’t work. Damaged force touch maybe?
Últimas 24 horas: 3
Últimos 7 dias: 5
Últimos 30 dias: 9
Duração total: 2,773
What model of watch are you putting the display on? Gonna compare the teardowns.
por Jessica Parnelli Fawkes
I looked at it myself, it seems the little gold antenna connector will not connect properly...
por BioMajuss
@BioMajuss are you sure that's the only issue?
If yes, you could easily work around by some manual wiring?
por franqus
Hey dies the Apple Watch 3 40 mm Display works on the Apple Watch 4 Nike 40 mm?
i want to know ist to Save Money
por Ps4 c1
