Ir para o conteúdo principal
At the 2004 North American International Auto Show, Nissan unveiled a completely redesigned Pathfinder for the 2005 model year.
14 Perguntas Visualizar todos
Help no brake lights but tail lights work
I have no brake lights but my tail lights work. I recently had a trailer brake installed in my 2008 Nissan Pathfinder. I don't know if this could be a cause of my problem. Any ideas? We have checked fuses and wires all seem to be good.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Sara Allread, could be a bad brake light switch.
Remove the contact from the switch and apply a small jumper between the pins on your cable. If the stop lights come on you know it’s a bad switch. There are really not a lot of other things in this circuit that would cause it.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Sara Allred será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 8
Duração total: 990
