Ir para o conteúdo principal
Apple's sixth-generation smartwatch, with optional cellular connectivity, released September 18, 2020. Model A2376, 44 mm.
47 Perguntas Visualizar todos
Where are the zif latches.
Would you be able to show in a close up how to unlatch the zif connectors in an Apple Watch series three screen replacement.  All instruction mention opening the latches as a necessary step.  But, I can’t see any latches and when I attempted to open the latches on my old screen, I broke them all.
Esta é uma boa pergunta?
Pontuação 0
2 comentários
Hi there Tom and thanks for the great question. I've passed this message along to someone who has more information and I'll (they'll) get back to you as soon as possible.
por
This question was migrated from https://meta.ifixit.com/Answers.
por
Adicionar um comentário
1 resposta
Solução escolhida
Hi Tom! Be sure you’re using our repair guides, not our teardown! I assume you’re talking about these connectors on the display.
If those photos aren’t enough to help you out, maybe our connector guide can help a bit with disconnection?
Imagem de Electronics Skills
Guia
Recognizing & Disconnecting Cable Connectors
Nível de dificuldade:
Fácil
8 minutes
Imagem de Apple Watch Series 3 Screen
Guia
Apple Watch Series 3 Screen Replacement
Difícil
2 - 3 hours
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Tom Baldauff será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 340
