Hi @popsthompson ,
What is the model number of the TV?
Does it also do this when using the various control buttons (Input, Vol Up and Down etc.) on the TV?
If it doesn't do this when using the control buttons it may be a problem with the IR sensor or sensor circuit in the TV.
If it doesn’t do this when using the TV control buttons is there a factory reset option in the TV menu options area that you can try?
Try a power refresh to see if this clears any corrupted data that may be stored in the TV.
Turn off the TV, turn off and totally disconnect the power from the TV, then press and hold the TV Power button for 30 seconds to drain any residual power from the TV. Reconnect and switch on the power to the TV, turn on the TV and check what occurs when using the remote and the TV control buttons.
I’m having the same issue with my new Samsung 55” 4K tv at the minute. All buttons in my Samsung remote turns the tv off, the smart things smart app that usually controls tv also turns tv off and the buttons on the tv to control menus also turns tv off after the 2nd or 3rd click. I have tried the reset, batters out of controller, camera looking at flashing light etc. All never worked. I now am waiting on a Samsung engineer coming out to look at it. Tv is just 1 month old.
por josephmccaff
This has just happened with my panasonic smart tv. Every remote, including firestick turned tv off and then on (what ever button was pressed - this happened).
I solved the problem by performing a factory reset.
I performed this by going to the set up menu then system menu/shipping condition!!
Once reset, I went through the start up procedure, reconnecting to wifi etc.
AND YES, IT WORKED!!!!
por lloyd game
Hi @ lloyd game
Just curious how you got through the TV menus as you said "Every remote, including firestick turned tv off and then on (what ever button was pressed - this happened)."
por jayeff
How did you get to system reset?
por karen rowley
I had the problem but my TV just started working again after 10 minutes
por John MacD
Mostrar mais 8 comentários
