Ir para o conteúdo principal
Smartphone projetado pela Xiaomi na linha Redmi Note.
Redmi note 4 charging issue :
1.It is not continuously charging …….after 5 min or in few min it will automatically charging stopped….after i re plugged its charging ..and again same issue.
one day its charging up to 3%. fullday it connected battery indication is glowing but at the end same 3%
what is the issue any suggestion vradhakrishnan25@gmail.com
please help me
i tried many things:
1. I replaced new battery….
2. mobile factory reset by “mi pc suite mode”
Esta é uma boa pergunta?
Pontuação 4
Adicionar um comentário
1 resposta
Solução escolhida
Try to resolder the USB port pins.
If you have a multimeter it is more easy to locate the problem. If you have one let me know and i will tell you where to start.
Esta resposta foi útil?
Pontuação 8
7 comentários:
Thank you bro .....the mobile power port pin is sometime shacking......i think it is broken..
thanks for the suggestion....
por Compartilhar
i'm glad it helped you
por Compartilhar
yes bro the issue is fixed as your suggestion .....i given to service center again ..they replaced the mobile power port pin now its working fine .......thank u bro........
por Compartilhar
Redmi 4 charging problem solve https://androidji.com/redmi-note-4-charg...
por Compartilhar
Thanks for the blog! here you will also find many useful blogs https://www.bpwltd.com/hangover-tamil-du...
por Compartilhar
Exibir mais 2 comentários
Adicionar a sua resposta
Radhakrishnan será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 28
Ao todo: 10,963
