What is the easiest way to remove and reinstall automatic transmission
do I drop the subframe
Esta é uma boa pergunta?
@scfoster according to the manual you need to :
Disconnect the negative battery cable
Remove the battery and the battery tray
Remove the air cleaner component
Remove the front tires and splash shield
Remove the steering gear and power steering pipe
Remove the front auto leveling sensor
Drain the atf
Here is the part from the manual that describes the automatic transaxle etc. Mazda_6-Automatic-Transaxle.pdf
Esta resposta foi útil?
YouTube has several step by step videos.
Also check out Mazda 6 club forum.
Últimas 24 horas: 4
Últimos 7 dias: 5
Últimos 30 dias: 8
Duração total: 451
