Ir para o conteúdo principal
A1708 / EMC 2978 — Lançado em outubro de 2016, este MacBook Pro de entrada mantém as suas teclas de função tradicionais (em oposição à Touch Bar OLED). A versão com teclas de função vem equipada com um processador Intel Core i5 e duas portas Thunderbolt 3.
Access to files on SSD drive.
Hi,
Can you please call me I’m looking for an adapter that allows me to plug in a 2016/2017 non touch bar SSD drive to either a USB-A or USB-C port to read and test drives externally.
I would need about 10 of them.
Apple Blade SSD 5GA 34+22 Pins NVMe
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
Pergunta mais útil
Sorry we don't call people - To expensive!
Sadly your model uses a very different SSD connector as you can see in this Desmontagem do MacBook Pro 13" com teclas de função do final de 2016 jump down to Step 10.
So far no one has created one. Give OWC a call to see if they have anything thats the best I can offer you.
Your only option is to get access to another Fn MacBook Pro which you can swap out the SSD to gain access to your files.
Esta resposta foi útil?
Pontuação 2
Would installing my SSD into another working mackbook pro work exactly the same? meaning i would need the apple id and password from my SSD?
Pontuação 0
I don't have 10, I had 15 made and I think I have eight left, but I would be happy to send you my PCB file, and you can send it to PCB way like I did and they can make you as many as you want, I know the design works, I've been using it for years. I designed a custom PCB adapter several years ago and had PCB Way build several of them, specifically to recover data from 38+22-MacBook Pro SSDs. They're 38+22-pin to USB 3.2 Gen2x2, so quite fast, they get the job done.
Email me.
  • Jackson
  • PhixesPhones@gmail.com
Pontuação 0
1 comentário:
My above comment has the caveat of, as long as you know your password, then you're fine you can use my adapter just like any SSD to USB adapter
por
Adicionar a sua resposta
kirk será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 12
Ao todo: 2,354
