Ir para o conteúdo principal
Model A1842. Released September 2017, the revision to Apple's 4th generation set-top-box featuring an A10X Fusion processor and 3 GB of RAM.
14 Perguntas Visualizar todos
AppleTV 4K - Looking for a source for a power supply
My AppleTV 4K won’t turn on and I believe I need to replace the power supply. Looks to be straight forward. However, I don’t know where to buy a new power supply. iFixit.com does not sell them. Any suggestions?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
I found this one on eBay Apple TV 4K TV4K A1842 PA-1310-2A REV X2 Internal Power Supply Board. Before you make the jump try a second power cord. You could still have a logic board failure. Make sure you can return it so you don’t waste your money.
Esta resposta foi útil?
Pontuação 1
1 comentário:
I had seen those on eBay and was not sure if I could trust. But it does appear to be the only option. I did try a new power cord, so it is definitely something more complex. Great point on being able to return the power supply in case that is not the problem.
por
I am going to try this:
https://www.newegg.com/
  1. Home
  2. Electronics
  3. Portable Electronic Devices
  4. PDA Accessories
  5. Thinkstar
  6. Item#: 9SIAJ90ATG3647
Pontuação 0
Adicionar a sua resposta
Eric será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 7
Últimos 30 dias: 22
Duração total: 1,943
