Ir para o conteúdo principal
The W123 chassis covers 240D's, 300D's, 300TD's, 280E's, and several other models of Mercedes coupes, sedans and wagons from model years 1977 to 1985.
Fuel Float Repair Info
While cleaning the fuel tank float on 1983 300D the aluminum wire (“V” shaped) which guides the float and helps send level info to gauge broke. I replaced it with same size copper wire. Would that effect the fuel gauge reading? What difference it makes if it is aluminum or copper while the other (“I “ shaped second wire in the unit) wire was copper as well.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
It will definitely affect the reading! But as far as I know, it should be okay if you never plan on driving with an almost completely empty fuel tank.
I don’t remember how much but the change will be in resistance to the wire so it will show either more or less than actually in the fuel tank.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
hhbabaturk será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 18
Ao todo: 192
