Ir para o conteúdo principal
The Olympus Stylus 1010 is a 10.1 MP digital camera with 7x optical dual image stabilized zoom. It has a 14.7 MB XD-Picture Card. The camera is 99 x 56 x 25 mm and weighs 136 grams.
7 Perguntas Visualizar todos
My lens is stuck.
I've tested the battery and it is fine. I've removed the memory card and held down the function button while turning the camera on. This hasn't solved the problem - the lens is still stuck. What else can I try?
Esta é uma boa pergunta?
Pontuação 1
1 comentário
من احتیاج به یک شارژر و یک باتری دارم برای دور بینم! باید چکار کنم؟
por
Adicionar um comentário
1 resposta
Solução escolhida
Irene Rosko, take a look at this blog. It does describe in detail how to deal with this very common error. Should any of those steps not clear up the problem, then I would think that your issue is related to the IC that controls image processing. If it has failed you will have to replace that. But try the less invasive suggestion first. Good Luck.
Esta resposta foi útil?
Pontuação 1
1 comentário:
My. Camera is a sz1114 megapixel
Olyumpus 20x wide
por
Adicionar a sua resposta
Irene Rosko será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 31
Duração total: 11,842
