Ir para o conteúdo principal
The Canon AE-1 is a 35 mm single-lens reflex (SLR) film camera for use with interchangeable lenses.
How do I replace the film door?
my film door latch got messed up and doesn’t close properly and long story short i need to replace it. i bought a replacement door on ebay, how should i go about replacing the film door?
Esta é uma boa pergunta?
Pontuação 0
2 comentários
Post a few pics of the damage so we are working on the correct side. Adicionar imagens a uma pergunta já existente
Are you able to lift the knob up and can see the latch within the body raise up?
por
yes i am able to lift the knob up but im not sure which latch you're referring to
por
Adicionar um comentário
1 resposta
Pergunta mais útil
@gracej
open the film door all the way. Remove the door by pulling the release pin in a downward direction.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
grace j será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 10
Ao todo: 1,349
