Time /Date are incorrect
The time and date are not correct and when I change them to correct ,the next time I turn it on it’s back to the wrong date..
Esta é uma boa pergunta?
Couple things to check. Out of misguided paranoia, is your Location turned off in the Action Center/All Settings/ Privacy/Location ? Should look like this:
Also, check this - Win + R/ services.msc Scroll down to Windows Time Check if it's running and on Auto trigger.
If not, r-click/select Properties/ set Startup to Automatic/ OK.
If these both check out and you try to turn off auto sync and manually set time.
And let me know how’s everything going after that, thanks!
Esta resposta foi útil?
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 9
Ao todo: 359
