Ir para o conteúdo principal
Repair Guides for Dell Desktops.
446 Perguntas Visualizar todos
spec difference between Optiplex 760 SFF and Optiplex 910 SFF?
I have a optiplex 760 sff and optiplex 910 sff , what is the differenc between the two in specs?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
Hi @fegelein3290 ,
Did you mean a Dell 9010?
Searching for Dell 910 brings no results
Here are the specs for a 760 SFF (see p.35)
Here are the specs for a 9010 SFF (see p.55)
Esta resposta foi útil?
Pontuação 1
there are variations on each model so I cannot say what exactly the difference is, but overall the 910 is going to have a newer and better CPU as well as more ram from what I could find. The 910 would be much faster and it looks like the 760 is using processors that predate the core i series so at this point in time, I would say that if you are looking at buying either you should 100% go with the 910
Pontuação 0
2 comentários:
both desktops can upgrade their cpus
por
the 760 isn't gonna have much of a chance to upgrade the cpu. you are stuck on the LGA 775 socket. No modern CPU uses that. Good luck upgrading and if you do, it will still be a terribly outdated CPU.
the 9010 is still the better call hands down.
por
Adicionar a sua resposta
Brayden S será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 158
