Ir para o conteúdo principal
Despertador analógico tradicional com dois sinos da LaCrosse. 16,5 cm de comprimento, 11,4 cm de largura, 5 cm de profundidade e 227 g de peso. Caixa de metal dourado, ponteiros e marcadores de hora luminosos, mecanismo de quartzo analógico e lente de vidro transparente.
Detached wires on analog twin bell clock
Hello,
my twin bell clock fell off the shelf and 3 wires got detached. Can anyone help me put them back into appropriate spots? There is one hanging from the bell part; another one from the battery piece, and the last one from the little compartment in the middle. Thanks for your help in advance.
Imagem
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Ania ZygZak  right now it looks like you are only supplying + to the clock. I would connect the wire marked with the green arrow to the clock mechanism. It is hard to see but it appears as if there was solder on the 2nd connector on the mechanism. See if that gets the clock going. I would need another view from the side (red arrows) to see if there are any solder pads and where the far right wire connects on the bell motor. there appears to be some writing on the mechanism any chance you can let us know what it says. I suspect a maker and model number which might help
Imagem
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Ania ZygZak será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 39
Ao todo: 1,799
