Battery Connector not separate on my model
Hi, my ibook won't run on a brand new fully charged battery. I took my ibook apart. The battery connector is not a separate part like your pictures. It appears to be integrated into the logic board.
Any suggestions?
Esta é uma boa pergunta?
5 comentários
Please give us the last three figures of your serial number.
por mayer
Thanks for the reply.
The serial # is UV4190YWQJP
por Nick
Apple iBook G4/1.0 12-Inch (Early 2004 - Op) Specs
Identifiers: iBook G4 - Early 2004 - M9426LL/A - PowerBook6,5 - A1054 - N/A
por mayer
There does dot appear to be a teardown of your model. Please give a complete description of what's happening with your machine. For reference here's an explosion of your parts: http://www.welovemacs.com/apibg41g12co1....
por mayer
If I unplug the power, the computer dies. I just purchased and installed a new battery. It's the third battery I've bought hoping the others were bad. None of them are bad.
The battery is good and I get 4 green lights when I push the button on the battery itself. The battery terminals appear to be intact, no wear whatsoever. But if I so much as wiggle the power cord, it dies. I can't determine if I need a DC - input, a Battery connector, or a Mother board.
Also, again, the battery connector does not match your photos. Any advice is welcome and appreciated.
Under the power indicator at the top right it says Battery Charged and is greyed out.
Under system profile: Power:
Battery Installed Yes
First low level warning No
Full Charge Capacity (mAh) 4252
Remaining Capacity (mAh) 4210
Amperage (mA) 0
Voltage (mV) 11070
Cycle Count 1
AC Charger Information:
AC Chargr (Watts) 65
Connected: Yes
Charging: No
por Nick
