Introdução
The motherboard includes all ports except the DC-In board.
Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
Use a pin (or anything you like) to remove the three rubber feet from the lower case.
Remove the following 7 screws from the edges of the keyboard area.
Three 2 mm Phillips along the right edge.
One 4.5 mm Phillips underneath where the magnet was.
One 6 mm Phillips with a small head in the lower left corner.
Two 6 mm Phillips with large heads, one in the upper left corner and one in the middle
Remove the following 15 screws:
Fourteen 3 mm Phillips.
One 5.5 mm Phillips in the upper left corner.
Lift the metal restraining bracket from the hard drive and place it aside.
Remove the following 5 screws and 3 nuts from the heat sink:
One 3.5 mm Phillips from the lower left corner of the heat sink.
Three 6 mm Phillips from around the fan.
One 7.5 mm Phillips at the top right corner of the heat sink.
One 4 mm nut from the side of the heat sink.
Two 4 mm screw nuts with attached springs from either side of the heat sink.
Remove the two Phillips screws securing the white plastic fingers of the I/O bezel to the metal framework.
17 outras pessoas concluíram este guia.
Documentos anexados
Um comentário
Just finished putting back together my iBook G4 12inch 1.92. After attempting to repair the infamous soldering issue of these machines, I put it back together and… it works! Thank you for your detailed instructions. If I had one suggestion, please list the screw sizes at all the steps for those putting things back together afterwards. Thank you again!
