Ir para o conteúdo principal
Informações de reparo e desmontagem para o mouse sem fio MX Master da Logitech. Lançado em 2015 e identificado pelos números de modelo M-R0052, 910-004956, 910-004955 ou 910-005228.
side scroll works only in one direction
my side scroll wheel works only one way no mater which way it turns , problem appeared after performing cleaning with compressed air
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Yeah, not a good idea to use an air duster on delicate parts. You’re going to have to open the mouse and see what’s up. You should probably buy new mouse skates before you open the mouse, as there’s a high likelihood that you’ll damage them taking them off to get at the screws. Either way, the mouse has gotta be opened. If you don’t see anything obvious that you can fix yourself, you’ll at least be able to take a photo so people can see what’s going on itn there. It sounds like an easy fix. Like the kind of thing you just look at and see what’s wrong. But you gotta open the mouse. Here’s a video for a different issue with that mouse, but it shows how to open it https://www.youtube.com/watch?v=KR9fLd_V...
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Piotr Kalisz será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 16
Ao todo: 795
